thanks for the suggestion, I will consider it.
But I still confused with the use of pair_style command.
The problem is as follows:
My potential is buck/coul, if I want to use a cutoff for the Buck (dispersion forces) and a sum of Ewald or PPPM for Coulombic interactions , the syntax would be, according to the manual:
- pair_style buck/coul cut long 7.5
kspace_style ewald 0.0001
but this make the followins error: invalid pair_style
if i put:
- pair_style buck/coul/cut long 7.5
generate this error: KSpace style is incompatible with Pair style
testing alternatives there are two options that work:
- pair_style buck/coul/long 7.5
- pair_style buck/coul/long long 7.5
question: Do any of the situation is that I want? generate, both runs, different thermodynamic values
lammps version I use is may2009 with the corresponding manual.
thanks for any suggestions,have a nice day !
Cristian
my input is:
units real
atom_style charge
lattice bcc 2.78
region superbox block 0 6 0 6 0 6
create_box 3 superbox
create_atoms 1 box
set group all type/fraction 2 0.477 3242
group oxigeno type 1
group resto type 2
set group resto type/fraction 3 0.19 3242
group silicio type 3
group litio subtract all oxigeno silicio
mass 1 16
mass 2 6.9
mass 3 28
set group oxigeno charge -1.38
set group litio charge +0.87
set group silicio charge +2.40
neighbor 0 bin
thermo_style custom step pe ke temp press
pair_coeff 1 1 40533.77691 0.351320 4954.646367
pair_coeff 1 2 55098.73098 0.248870 765.3239006
pair_coeff 1 3 247362.358 0.208510 1632.163337
pair_coeff 2 2 154857.0464 0.146420 0 #118.2164436
pair_coeff 2 3 5515573.834 0.106060 0 #252.1135755
pair_coeff 3 3 20126639610 0.065700 0 #537.6684751
velocity all create 4000 87287
fix 01 all nve/limit 0.1
thermo 100
timestep 1
run 5000
unfix 01
fix 1 all nvt 4000 4000 20
thermo 500
run 2000
unfix 1
fix 2 all nvt 4000 3000 20
thermo 500
run 200
unfix 2
fix 3 all nvt 3000 3000 20
thermo 500
run 2000
unfix 3
fix 4 all nvt 3000 2000 20
thermo 500
run 200
unfix 4
…follows !
