Hi. I've posted a few times about the possibility of adding reversible
bond formation to LAMMPS, and the general opinion has been that it is
difficult, and will require a lot of changes to the code in many places.
Well, it's not easy (if one wants to preserve parallelizability: doing it
in a serial version IS easy), but I think I have an idea of how it might be
done in parallel while minimizing changes to the code, and am at a point
where I'd like to hear further comment:
1) Problem: Dynamically changing the overall number of bonds stored (in
atom->bond_atom and neighbor->bondlist) is very difficult.
Solution: Avoid this by including the maximum number of POSSIBLE bonds in
the data (or restart) file. Treat inactive "sticky" bonds as
self-bonds. For example, if atom i is a "sticky" atom with two reversible
bonding sites, include these two in the number of bonds written down in
the data file, and in the "Bonds", include two lines
j stickybondtype i i
j+1 stickybondtype i i
This, I think, is a workable order-N solution as long as atoms have a
limited number of sticky sites, as they should in any "physical" model.
Of course, one has to do something to prevent self-forces (from atoms
being "bonded" to themselves), but this is easy.
2) Using Monte Carlo to form/break reversible bonds is tricky for a
parallel MD simulation:
In a serial simulation, one can simply (within the bond-force routine
such as bond_fene.cpp) loop over the sticky sites, test
whether other sticky sites are nearby (this can be made order-N by using
the pair neighbor list in the search, and there are additional ways of
making it efficient if the concentration of sticky atoms is low). For
nearby sites, use Metropolis MC to break/form bonds, and update
atom->bond_atom and neighbor->bondlist accordingly. This of course has to
be done BEFORE the forces are added up. This appears to work fine.
However, in a parallel simulation, this model breaks down. Suppose you
form a bond between atoms i and j, where i is owned by processor A and j
is owned by processor B. If the MC routine running on A forms the bond,
how does B know the bond has been formed? Also, one has to worry about
whether such pairs are considered more often (specifically, twice as
often) than pairs of atoms owned by
the same processor - one doesn't want to introduce spatial
inhomogeneities.
These are of course typical examples of why parallel MC is hard. I can
think of a couple ways of dealing with this:
1) When it is time to run the MC (I plan to do this infrequently, say once
every hundred timesteps), pause the parallel MD run, collect the ENTIRE
bondlist and set of coordinates into large vectors (i. e. of length
natoms, nbonds), do the MC bond forming/breaking on one processor, then
distribute the new bondlist among the processors and unpause the
MD. I think I know how to do this (main question is whether to do it in a
fix or within the bond-force routine), but it has disadvantages such as the
memory required for the large vectors.
2) Referring to the above paragraph, if processor A forms an i-j bond,
send a message IMMEDIATELY to processor B, so that B can synchronize its
bondlist and atom->bond_atom to the change. This seems more elegant
(and would require less memory) but seems
harder and trickier, with "unknown unknowns" (at least to me). For
example, it would seem to require processor A to know which processor atom
j belongs to. I don't know whether LAMMPS has this functionality, or if
not whether it would be difficult to add. In general, one would be
sending a lot of small MPI messages rather than a few huge ones - I don't
know which is faster. Actually I don't care that much about speed, the
memory issue and "order-N-ness" are more important.
OK, eager to hear any thoughts!
Rob
