Hi, all.
I wonder if LAMMPS can simulate coarse-grained mobile walls (moving along z-axis only) with NPT.
Either coarse-grained MD or DPD will be fine.
Could anyone please give me any idea?
Thank you.
Hi, all.
Thank you.
You can apply NPT in any periodic dimension.
You can apply a wall in any non-periodic dimension.
But the 2 are not meant to be used together
in the same dimension, which doesn't really make
sense to my mind.
You can also use fix aveforce to use a "wall" made
out of atoms a push on it. Again that cannot be
done with NPT in a particular dimension since
your system would be non-perioidic in that dim.
