Following Steve's comment I actually tried configurations that should have
worked OK and did not. They include the perfect beta-cristobalite structure
and also an amorphous configuration that was minimized with another SiO2
potential.
Another thing is that I tried to run beta-cristobalite with a thermostat
for ~3-5 ps, and even using velocity rescaling every step, there was a
temperature spike which filled the crystal with defects and turned it
nearly to an amorphous.
I was wandering if someone could actually spot any problems with the input
file or the format of the data file. Any help/suggestions are welcomed.
Input script seems fine other than that the pair coeffs seem
large - are you sure they are correct for metal units?
Paul - do you have a simple silica geometry and input script
you ran for your silica pore models which you can send
to Lilian?
