[lammps-users] msd with varying Temperature
I’m having trouble with the temperature dependent mean square displacement msd. I want to calculate the diffusion coefficient for varying temperature of molecules with Knudsen conditions inside CNT forests.
However the diffusion coefficient doesn’t change with varying temperature!
My simulation starts with two overlying CNT’s, which are then displaced in x and y direction to get a periodic CNT forest in all 3 dimensions.
Then I follow the movement of 25 atoms, where forces between these atoms are turned off (Knudsen condition).
I have applied NVE ensemble with temp/rescale and an initial velocity according to the temperature, see below.
The calculated diffusion coefficient fluctuates without a clear trend between 1E-4 and 1E-5 for temperatures between -150 and 1300 °C.
Any help or comments are appreciated.
Here is a simplified input script:
atom_style atomic
read_data run.data
group CNT1 type 1
etc.
neighbor 2 bin
neigh_modify delay 1
displace_atoms CNT1 move 9.6 0 0 units box
displace_atoms CNT2 move 0 9.6 0 units box
#Potential forces
pair_style hybrid lj/cut 15 airebo 2 1 1
pair_coeff * * airebo CH.airebo C C NULL NULL NULL NULL NULL
pair_coeff 3* 3* none
pair_coeff 1 3* lj/cut 0.005549 3.605
pair_coeff 2 3* lj/cut 0.005549 3.605
velocity CNT create $t 12345
velocity CH4 create $t 131183
fix 1 all nve
timestep 0.0005
fix 8 all temp/rescale 40 ${t2} $t 0.1 1
#coordination number and msd for every atom
compute 1 1 coord/atom ${cutoff}
compute 2 1 reduce sum c_1
variable comp equal c_2
variable step equal step
fix 9 1 msd 200 diff_1.txt
fix 10 1 print 60 “{step} {comp}” file comp_1.txt
etc.
run 4000000
Best Regards
Thomas Siegfried
