[lammps-users] msi2lmp
I am trying to use some of the Materials Studio(MS) file to be converted in to Lammps input file using msi2lmp.
I compiled the make file and got the exec "msi2lmp.exe". I tried the examples it worked fine.
I also have *.car *.mdf file of my structure from MS and tried to convert to lammps format but i couldn't.
I am trying to use clayff forcefield and hence i copied the *.frc file to biosym_frc_files dir.
Could you please kindly help me in this regard.
error
zsh: segmentation fault msi2lmp.exe water -2001 -class I -frc clayff.frc
Thanks in advance
Sincerely,
Naresh
debugging a segmentation fault is not lammps specific.
i recently posted a quick summary on this list of how
you can identify the location of the problem. however,
it was also mentioned several times that msi2lmp is
effectively unmaintained at this time, so you will
have to solve what ever problem you discover in the
debug process by yourself.
