I am trying to write a Dynamo setfl file containing three EAM Finnis-Sinclair (FS) type potentials for an Fe-Cr alloy. The three potentials are for Fe-Fe, Cr-Cr, and the Fe-Cr cross-interactions.
I have a specific potential form for Fe-Cr and as such do Not want LAMMPS to mix the other two potentials for me to create a third Fe-Cr cross-potential.
I can get LAMMPS to work with just the Fe-Fe potential, but I get errors when introducing the cross-potential (for Fe-Cr). Looking through messages in the LAMMPS mail list archives, I believe that I should accomplish this by placing all three potential in the same Dynamo setfl file.
Looking over the “read_file” function in “pair_eam_fs.cpp” file of the LAMMPS source code, I believe I understand how to implement EAM-FS potentials for Fe-Fe and Cr-Cr interactions, but I don’t know how to do it for the Fe-Cr cross potential.
If I’m right, the Dynamo setfl file format should follow this structure (Let i = for element i):
Line 6: [Atomic Number(i)] [Atomic Mass(i)] [Lattice Constant(i)] [Lattice Type(i)]
Line 7 to A: [Embedding Function(i) = F(rho(i))]
Line A+1 to B: [Electron Density(i) = rho(i)]
Line B+1: [Atomic Number(j)] [Atomic Mass(j)] [Lattice Constant(j)] [Lattice Type(j)]
Line B+2 to C: [Embedding Function(j) = F(rho(j))]
Line C+1: [Electron Density(j) = rho(j)]
(Continue on for however many elements you have)
Line D: [Pair Potential between i and i]
Line E: [Pair Potential between i and j]
Line F: [Pair Potential between i and k]
Line G: [Pair Potential between n and n]
If I am right, there seems to be nowhere to specify the electron density function for the cross potential. If I am wrong…I’d love to know where I’m wrong.
Any help you can offer me is greatly appreciated!
Cheers,
-Brian Frisbie
