lammps uses in its nph/npt/nvt schemes the algorithm proposed in Shinoda, Shiga, and Mikami, Phys Rev B, 69, 134103 (2004).
Basically, the cell matrix h = [a b c], with the three vectors a, b and c denoting the three edges of the cell box, is transformed into a p_g, the “modularly invariant form of the cell momenta”.
The quantity p_g is symmetric and lammps uses the governing equations given in Eq. (1) of mentioned paper.
I have following questions since in FixNH::nh_omega_dot() a dilation[6] is calculated
How is the cell momentum p_g linked to the cell matrix h? Can they be transformed to each other?
In FixNH::remap() the box is adjusted depending to new size/shape, which is governed by dilation[6].
Why ( in FixNH::nh_omega_dot() ) are dilation[0]-[2] calculated like dilation[i] = exp(dtoomega_dot[i])
and dilation[3]-[5] like dilation[i] = dtoomega_dot[i]?
Thanks for help and thank you for the answers to my last questions,
Manfred
I'll let Aidan answer these Qs as he did the implementation
of the latest NPT version.
Manfred,
Here are responses to your two questions.
1) p_g = W*omega_dot, as in the code comment below:
// barostat energy is equivalent to Eq. (8) in
// Martyna, Tuckerman, Tobias, Klein, Mol Phys, 87, 1117
// Sum(0.5*p_omega^2/W + P*V),
// where N = natoms
// p_omega = W*omega_dot
// W = N*k*T/p_freq^2
// sum is over barostatted dimensions
2) The reason for the difference is that the dilations correspond to
increments of the h-matrix according to the following ODEs:
h_dot[0] = omega_dot[0]*h[0]
h_dot[1] = omega_dot[1]*h[1]
h_dot[2] = omega_dot[2]*h[2]
h_dot[3] = omega_dot[3]*h[2]
h_dot[4] = omega_dot[4]*h[2]
h_dot[5] = omega_dot[5]*h[1]
The indices are those used for omega_dot[6] and dilation[6] in the code:
(psuedo-Voigt notation): 0 = xx, 1 = yy, 2 = zz, 3 = yz, 4 = xz, 5 = zy
Aidan
thank you for the answers.
That brings me to another question:
The implementation of h is very smart, vector a is always pointing in x direction and obtaining h with
a = (xhi-xlo,0,0), b = (xy,yhi-ylo,0) and c = (xz,yz,zhi-zlo) leads always to six non-zero components.
When h_dot is updated it follows with p_g = W*omega_dot:
h_dot = p_g/W * h
[ 0 5 4 ] [ 0 5 4 ] [ 0 5 4 ]
[ - 1 3 ] = [ - 1 3 ] * [ - 1 3 ]
[ - - 2 ] [ - - 2 ] [ - - 2 ]
( “-” indicates zero).
Shouldn’t it be something like:
[ 8 1 3 ] = [ 5 1 3 ] * [ - 1 3 ]
[ 7 6 2 ] [ 4 3 2 ] [ - - 2 ]
p_g is symmetric and hence all positions of h_dot change (h_dot is non-symmetric).
I know that the dilation[6] is taken to update the cell shape, but h_dot is even different in positions 0-5 in the preceding two equations.
Thanks, Manfred
2010/6/7 Thompson, Aidan <[email protected]>
