Hi all,
I’ve got two related problems with damping parameters in Nose-Hoover integration in the canonical and isothermal-isobaric ensembles, so I’m going to lay both of them out. Sorry about the doubly long text here! I’m using the 8 Oct 2010 version of LAMMPS in serial.
First, when I run with an NVT or NPT ensemble and Tdamp < timestep (but not for Tdamp >= timestep), I get bad temperature values (as with thermo output and script below using the attached alpha-quartz data file). This seems to be independent of pair style, although I haven’t tried turning coulombic interaction off. Has anyone encountered this before? Is this a known limitation of Nose-Hoover integration in LAMMPS, or a bug, or do I just need to use unusual neighbor and neigh_modify settings to make this possible? I didn’t find any clues in a quick look at the discussion of Verlet integration with NH equations of motion in the Tuckerman paper cited in the doc/fix_nh page.
Script:
aq.data (82.9 KB)
tyler,
Hi all,
I've got two related problems with damping parameters in Nose-Hoover
integration in the canonical and isothermal-isobaric ensembles, so I'm going
to lay both of them out. Sorry about the doubly long text here! I'm using
why would you even _want_ to do that?
you could just as well use temp/rescale.
the whole point of nh-thermostats is to not
interfere with the dynamical properies of
the system much and ideally only provide
a very weakly coupled heat bath.
if you need to move energy in or out of
your system that drastically, you are much
better off with berendsen, langevin, or even
temp/rescale.
cheers,
Hi Axel,
Thanks, that’s a good point. I was unhappy with the ~30K temperature fluctuations that I was getting in my thousand-atom system with tdamp > timestep, but I suppose up-sizing would help there, and if not, I’ll turn to other thermostats.
Any thoughts on the Pdamp problem? I get immense pressure fluctuations with reasonable values of Pdamp, but maybe again that’s because of the size of my system.
Also, thanks for making topotools and imd, they’re great!
Tyler
You can't use damping constants near one timestep
in value with Nose/Hoover - they will not work. You
need a damp of about 100 timesteps for temperature
and about 1000 for pressure.
