Dear LAMMPS users,
I use this command in my .in file:
fix 1 all npt/asphere 1 1 1 xyz 0.1 0.1 0.1
but I get this error:
ERROR: Illegal fix nvt/npt/nph command
As much as I looked in LAMMPS manual I think there is nothing missed in the command (fix ID group−ID npt/asphere Tstart Tstop Tdamp xyz Pstart Pstop Pdamp)
Would you please help me to fix this error?
Thanks a lot,
Zahra
Which version of the code are you using? The commands for the Nosé-Hoover stats have changed recently: see http://lammps.sandia.gov/doc/fix_nh.html and http://lammps.sandia.gov/doc/fix_npt_asphere.html for the new syntax. (Try putting “temp” before “Tstart” in your example above.)
–AEI
The new version of your command would be:
fix 1 all npt/asphere temp 1 1 1 iso 0.1 0.1 0.1
btw, generally I expect to see Pdamp >> Tdamp >> timestep.
