[lammps-users] Number of hydrogen bonds
Dear LAMMPS users
I want to calculate number of hydrogen bonds in my system. in this system there are an amino acid and some water.
How to do this calculation?
Thanks in advance,
Yasti
I don't think this is a built-in capability in LAMMPS, which means you will either have to do this as a post-processing calculation, or write a fix or compute to do this in the code.
--AEI
I suggest post process, and not writing a fix. I bet you end up playing around with the H-bond criteria.
Matt
Dear LAMMPS users
typically, this is done in post-processing. you have to find
a way to signal the program in question which atom is a
hydrogen bond donor, which a hydrogen bond acceptor,
and which the hydrogen. LAMMPS doesn't know anything
like that from its input.
finally, there are multiple definitions for hydrogen bonds
and you should have a look into the literature which would
be the most appropriate one. typically, a distance and an
angle criterion.
cheers,
Dear Ahmed, Matt and Axel
Thanks a lot for your help.
Yasti
One additional thought. If you can define a H bond by
a distance criterion, then you could possibly use compute coord/atom
with the appropriate O and H atoms in the group. If the
H bond def is more complicated (but still presumably a function
of local geometry), then you could write a compute hbond/atom
command, using compute coord/atom as the template,
and stick in the geometry calc you need to do.
