Dear lammps users,
I used fix nvt command to set up the desired temperature. However,
the equilibrate temp of the system is ~350K much lower than my target
500K, and it is not a constant. Can anyone point out what's wrong in
my input file below? thanks.
Haibin Chen Ph.D.
Mechanical Engineering Dept
Carnegie Mellon University
Pittsburgh, Pa, 15213
# study CnT with REBO potential
# This input file is used in serial job
# 03/19/2010
# initialization Section
atom_style atomic
pair_style airebo 3.0 1 1
boundary f f p
read_data ${datafile}
pair_coeff * * /home/haibin/lammps/lammps-8Feb10/potentials/CH.airebo C
neighbor 2.0 bin
neigh_modify delay 5 check yes
timestep 0.0005
thermo_style custom step temp etotal pe ke
group cnt type = 1
thermo 100
#velocity cnt create 1000 87287
#fix 1 cnt nvt 1000.0 1000.0 100.0
dump 1 cnt atom 100 dump.cnt
dump 2 cnt xyz 10 dump.xyz
#minimize 1.0e-7 0.0001 10000 100000
velocity cnt create 500 87287
fix 1 cnt nvt 500.0 500.0 10.0
run 2000
Temp, TotE, output
0 500 -1739.3394 -1754.786 15.446587
100 386.0122 -1739.3356 -1751.2608 11.925142
200 368.58633 -1739.3266 -1750.7134 11.386802
300 357.97876 -1739.3276 -1750.3867 11.0591
400 358.36626 -1739.3299 -1750.4009 11.071071
500 286.28365 -1739.3187 -1748.1629 8.8442107
600 336.21285 -1739.3237 -1749.7104 10.386682
700 331.43811 -1739.3198 -1749.5589 10.239176
800 350.27195 -1739.3236 -1750.1446 10.821013
900 361.61857 -1739.3216 -1750.4931 11.171546
1000 328.71831 -1739.3161 -1749.4713 10.155152
