To Whom It May concern
Dear all:
I make a fix command inorder to add atom frequently, into the vacuum space inside the box.
I use the fix_insert as a templet. When the atoms have been added there will show an error message which is "Lost atoms original ...." and I found that it's due to the numbers of new atoms are not the sasm with the old value. So I add change the atom->natoms just after the insertion.
Is that will make any trouble or misstake during the simulation.If so can anyone give me a suggestion.
Thank you very much!
John
