Dear, everyone
When I run the simulation with a script input file.
In the input script , run 20000 timestep first.After it is finished,
then setting up run 20000 occured error:
The error occured as follows:
LAMMPS (21 May 2008)
Reading restart file …
orthogonal box = (-36.6375 -19.9841 -19.9841) to (36.6375 19.9841 19.9841)
2 by 2 by 2 processor grid
6960 atoms
6640 bonds
9120 angles
11020 dihedrals
Finding 1-2 1-3 1-4 neighbors …
4 = max # of 1-2 neighbors
6 = max # of 1-3 neighbors
18 = max # of 1-4 neighbors
17 = max # of special neighbors
60 atoms in group C60cent
60 atoms in group C60win
6840 atoms in group IL
Resetting global state of Fix 1 Style npt from restart file info
PPPM initialization …
G vector = 0.123534
grid = 10 8 8
stencil order = 5
RMS precision = 0.000407645
brick FFT buffer size/proc = 810 80 810
Setting up run …
Memory usage per processor = 13.9493 Mbytes
Step Temp E_pair E_bond KinEng E_mol Volume Press Epp
220000 275.36959 -36708.121 1888.6238 5712.1172 4508.7312 117053.13 -245.43537 -16.683765
220500 283.19271 -36007.347 1243.6702 5874.3959 2926.9273 123601.3 -240.98533 -8.5403246
420000 274.27526 -36738.893 1896.3985 5689.4171 4465.1822 117158.07 283.29729 -15.903971
Loop time of 27919.7 on 8 procs for 200000 steps with 6960 atoms
0.4ns run 27919.7/3600=7.75hours
Pair time () = 16911.8 (60.5732)
Bond time () = 258.017 (0.924138)
Kspce time () = 8132.59 (29.1285)
Neigh time () = 819.54 (2.93535)
Comm time () = 1350.19 (4.83599)
Outpt time () = 1.73096 (0.00619977)
Other time (%) = 445.787 (1.59668)
FFT time (% of Kspce) = 1230.47 (15.1301)
FFT Gflps 3d (1d only) = 0.0134431 inf
Nlocal: 870 ave 897 max 836 min
Histogram: 1 0 0 0 2 1 2 1 0 1
Nghost: 12672.9 ave 12741 max 12604 min
Histogram: 1 1 0 1 1 1 0 2 0 1
Neighs: 631068 ave 651013 max 616281 min
Histogram: 2 1 1 0 0 2 0 1 0 1
Total # of neighbors = 5048546
Ave neighs/atom = 725.366
Ave special neighs/atom = 6.84483
Neighbor list builds = 7568
Dangerous builds = 1
Respa levels:
0 = bond angle dihedral improper
1 =
2 = pair-inner
3 = pair-outer kspace
WARNING: One or more respa levels compute no forces
G vector = 0.123513
grid = 10 8 8
stencil order = 5
RMS precision = 0.000407838
Setting up run …
p0_27933: p4_error: net_recv read: probable EOF on socket: 1
rm_l_7_2090: (27920.242188) net_send: could not write to fd=5, errno = 32
p6_2054: (27920.332031) net_send: could not write to fd=5, errno = 32
rm_l_3_27997: (27921.347656) net_send: could not write to fd=5, errno = 32
p7_2073: (27930.253906) net_send: could not write to fd=5, errno = 32
p3_27980: (27931.359375) net_send: could not write to fd=5, errno = 32
p0_27933: (27933.519531) net_send: could not write to fd=4, errno = 32
I performed the parallel simulation with 4 processors.When I set one run
in the input script, it will not occured any error.
The version of the lammps is lammps-24Oct08.
I used pgCC with mpich1.2.7 on AMD machines
I will appreciate your help
Fred
