Dear Steve
The error is still unresolved. Program seems quite correct. I’m puzzled
that what is the problem.
LAMMPS (7 Jul 2009)
Lattice spacing in x,y,z = 2.5 2.5 2.5
Scanning data file …
4 = max bonds/atom
6 = max angles/atom
18 = max dihedrals/atom
2 = max impropers/atom
Reading data file …
orthogonal box = (-0.5 -0.5 -0.5) to (0.5 0.5 0.5)
1 by 1 by 1 processor grid
ERROR: Pair coeff for hybrid has invalid style
Program :
Created by charmm2lammps v1.8.1 on Sat Mar 13 19:52:04 IRST 2010
#neigh_modify delay 2 every 1
lattice fcc 2.5
region A block -120 120 -120 120 -120 120
atom_style full
bond_style harmonic
angle_style charmm
dihedral_style charmm
improper_style harmonic
pair_style hybrid lj/charmm/coul/long 8 10 tersoff lj/cut 2.5
read_data proteinnanotube.data
pair_coeff 132 132 lj/charmm/coul/long 100.0 2.0
pair_coeff * * tersoff SiC.tersoff NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL C
pair_coeff 1*32 33 lj/cut 1.0 1.0
#pair_modify mix arithmetic
kspace_style pppm 1e-4
group nanotube id > 3280
displace_atoms nanotube move 30 0 0
special_bonds charmm
fix 1 all nve
fix 2 all shake 1e-6 500 0 m 1.0
velocity all create 300.0 12345678 dist uniform
thermo 1
thermo_style multi
timestep 0.5
#restart 10 2KOT_autopsf.restart1 2KOT_autopsf.restart2
#dump 1 all atom 10 2KOT_autopsf.dump
dump 1 all xyz 100 proteinnanotube.xyz
dump_modify 1 image yes scale yes
run 20000
Actually, SiC.tersoff have been copied from /lammps-27Aug09/potentials/SiC.tersoff to my directory without change the information within it, Does need to modify its information? if yes, How to do it?
Thanks a lot for your response.
Best regards
Farrokh
