Dear Dr. Alex,
Thank you for your valuable comments. Till now, I could not solve this problem. I enclose the input file and potential data file and read_data file.
Data6.txt is read_data file
dataa.table, data.table and dataaa.table potential files
input.txt is input file.
I request you to check my input file and potential data file so that I can remove this problem. Give adequate suggestion.
Thanks and best regards
Dr. Sankar, MAE, NTU, Singapore
— On Thu, 27/1/11, Axel Kohlmeyer <[email protected]…29…> wrote:
> From: Axel Kohlmeyer [email protected]
> Subject: Re: [lammps-users] pair distance < table inner cutoff error problem
> To: “sankar kumar” <[email protected]…16…>
> Cc: [email protected]
> Date: Thursday, 27 January, 2011, 7:09 AM
> On Thu, Jan 27, 2011 at 2:58 AM, sankar kumar <[email protected]…16…> wrote:
> > I am working on course grain bead spring model (fene)using lammps md simulator. I am using some potentials as tables using pair_style table command which are not in lammps… But after running it shows pair_distance < table inner cutoff error. Please inform me how I can solve this problem.
> some particles are obviously getting too close. you have to generate your
> tables in such a way so that they include smaller r values.
> please note that when using tabulated potentials, the “edges” are always
> a bit unphysical so it is good practice to make the tables to significantly
> beyond those ranges and use a high enough resolution.
> cheers,
> axel.
> > Sincerely yours
> > Dr. Sankar
> > NTU, Singapore
> > Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
> > Finally, a world-class log management solution at an even better price-free!
> > Download using promo code Free_Logger_4_Dev2Dev. Offer expires
> > February 28th, so secure your free ArcSight Logger TODAY!
> > http://p.sf.net/sfu/arcsight-sfd2d
> > _______________________________________________
> > lammps-users mailing list
> > [email protected]…44…s.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/lammps-users
> Dr. Axel Kohlmeyer
> [email protected] http://goo.gl/1wk0
> Institute for Computational Molecular Science
> Temple University, Philadelphia PA, USA.
input.txt (2.21 KB)
data6.txt (7.2 KB)
data.table (105 KB)
dataa.table (52.8 KB)
dataaa.table (52.8 KB)
