I am trying to use the new pair style born/coul/long. I updated my old LAMMPS to the latest version and changed form lj/cut/coul/long to this new pair style. The problem is that I encounter some errors which I’m not even sure are because of my code, or the way LAMMPS was build on our machines. The following is what I get. I’d be thankful if you have some input on that.
Meysam:
This looks more like an installation issue than a code issue. What happens if you just try to use pair lj/cut/coul/long, as you did before? Does it run normally, or do you still get errors?
It looks like a problem with the PPPM solver. I would
try to run bench/in.rhodo and see if it works. If it
does, then try what Ahmed suggested and focus on what
is different about your problem vs the benchmark.
