Hi
I want an example for pair_style table
thanks
In this little example script, you can run it once to
produce a table file via the pair_write command
and pair_style lj.cut.
Then run it again with pair_style table instead of
pair_style lj to use the tabulated file. The 1st 2
pair table options work and give the same answer
as pair_style lj.cut (or close), The third is crashing
for some reason ... I need to look at that.
