[lammps-users] Parallel Tempering Output
I have a quick question on the output of the log file from a parallel tempering run. I've read the documentation, but I feel it is a bit ambiguous and so I just want to verify with fellow users.
In the output below:
Running on 16 partitions of processors
Step T1 T2 ...
0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
500 1 0 3 2 5 4 6 7 8 9 10 11 12 13 14 15
1000 2 0 4 1 5 3 6 7 8 9 10 11 12 14 13 15
1500 2 1 4 0 5 3 6 7 9 8 10 11 12 14 13 15
2000 2 1 3 0 6 4 5 7 10 8 9 11 12 14 13 15
2500 2 1 3 0 6 4 5 7 11 8 9 10 12 14 13 15
Do the columns represent distinct replicas and the index numbers represent the different temperatures of the tempering spectrum? Initially, I assumed that the columns where the different temperatures, and the index numbers were the distinct replicas as they swapped around. Sorry if this is obvious,
Jose
It's confusing b/c the number of replicas = # of Temps.
TN means the temperature being simulated by replica #N.
Replicas are numbered 1 to N.
Temperatures are numbered 0 to N-1.
So an entry of Y in the Xth column means that
Replica X is currently assigned Temp Y.
I'll add this explanation to the temper command doc page.
