Hello Users,
I would like to understand a bit more about the output files from a parallel tempering run. I have attached an input file here (in.system). This is a toy file that I am using to figure out how the tempering is implemented etc…
- The output file “log.lammps” contains:
Step, T1, T2, …
Does this describe the replica-index at this instant in time present at the first
temperature, at the second temperature and so on?
I get the thermodynamic information in files: “log.lammps.0, log.lammps.1, …”
If I would like to look at the instantaneous potential energy of the system that is at 300K,
which file should I look at? Or, should this value be picked up from different files,
depending on which replica ID is currently at 300K?
My dump files are named: dump.300.system, dump.302.system, …
Is the file named dump.300.system, the one that has the configurations for 300K? It
appears obvious, but I thought I would get this confirmed.
Thanks for your help,
Cheers,
Bala
http://www.jncasr.ac.in/bala
in.system (782 Bytes)
Answers below:
Hello Users,
etc..
1) The output file "log.lammps" contains:
Step, T1, T2, ...
at the first
Yes, I think that's right.
2) I get the thermodynamic information in files: "log.lammps.0,
log.lammps.1, ....."
different files,
The log and dump files are written by a processor (or processor group),
for the replica it owns. That replica changes T over time (due to exchanges).
In other words, which replica is at 300K is changing over time. So those
values are not in 1 file.
3) My dump files are named: dump.300.system, dump.302.system, ...
for 300K? It
It depends on how you named your files, but the previous answer
should help. The dump files are also per-processor-group, not T.
See below:
Thanks Steve.
1) The line in my input for dump is:
variable t world 300.0 302.0 305.0 309.0 314.0 319.0 324.0 329.0
dump 1 all custom 1000 dump.$t.system tag mol type xu yu zu
So, although the filename could be "dump.300.system", it could contain
configurations from other temperatures if that processor group had gotten
its configuration exchanged. Is this right?
yes, correct
2) Is there a way to flush the log.lammps file in a parallel tempering run?
You could put in a flush() statement after the file write. Search for
flush in the code and you'll see where this is done elsewhere.
