I just upgraded to the most recent version of LAMMPS, and it seems that
passing variables from the command line does quite work the way it used
to. For example, running LAMMPS with the options
lmp -var foo bar
used to create a variable ${foo} which evaluated to "bar". Now, however, I
get the error message "ERROR: Invalid thermo keyword in variable". The
reason is probably that this command line argument is treated like
specifying "variable foo equal bar" in LAMMPS, which means that I can only
use a valid equation as the variable content.
Is there any way to pass arbitrary strings to LAMMPS variables from the
command line? This was a very useful feature, for example passing
filenames etc.
Lutz
