[lammps-users] phonon dispersion curves
Majid;
Why are you limiting it to a particular potential? If you are using forces
EAM is a many body potential, you can’t use the same pairwise calculations as LJ or Nbody potentials. If there is demand for the pairwise form of these potentials I’d consider writing those modules as well.
to find the phonon dispersion curves, you might as well use a lattice
dynamics program such as GULP.
I have thought about this, and the MD way is to just use the atom motions
since phonons are just wave decompositions of aggregate motions.
In LAMMPS this could be generalized to any region described by a lattice,
somehow mapping a ‘type’ to the atoms for unit cells with basis of more than
one atom.
Also, I’m not sure what the benefit is to have LAMMPS do it since you have
to have a time series of the motions. So it would be best to do it as a
post-process.
Of course we could use GULP, but then I’d be running 2 separate simulations which requires twice the effort and twice the computational resources. Also I don’t think GULP uses the standard tabulated EAM potentials.
-AdamC
To clarify my question, who do you need a potential at all? Phonons are just wave descriptions of the motions. For each wave you have its wavevector and frequency and that’s your dispersion curve.
