I’m doing a calculation which requires the velocities of ghost atoms.
Following Steve Plimpton’s suggestion I’m using atom_style dpd, but
my tests appear to show that the velocities of the ghost atoms are
not identical to those of the parent atoms.
I attach the compute, input and output files which test this. For
simplicity I consider a single FCC cell with lattice parameter 5.0, and
only print out the first few ghosts. At the zeroth step I get the following
results and everything appears to be fine:
atom 0 x= 0.0000000000 y= 0.0000000000 z= 0.0000000000
vx= 0.0004940417 vy= 0.0009573655 vz= 0.0013279029
atom 1 x= 2.5000000000 y= 2.5000000000 z= 0.0000000000
vx= -0.0006975682 vy= 0.0009922590 vz= -0.0000905373
atom 2 x= 2.5000000000 y= 0.0000000000 z= 2.5000000000
vx= -0.0004465096 vy= -0.0010397911 vz= 0.0002940638
atom 3 x= 0.0000000000 y= 2.5000000000 z= 2.5000000000
vx= 0.0006500360 vy= -0.0009098333 vz= -0.0015314294
atom 4 x= 5.0000000000 y= 0.0000000000 z= 0.0000000000
atom 5 x= 7.5000000000 y= 2.5000000000 z= 0.0000000000
atom 6 x= 7.5000000000 y= 0.0000000000 z= 2.5000000000
atom 7 x= 5.0000000000 y= 2.5000000000 z= 2.5000000000
atom 8 x= -5.0000000000 y= 0.0000000000 z= 0.0000000000
atom 9 x= -2.5000000000 y= 2.5000000000 z= 0.0000000000
atom 10 x= -2.5000000000 y= 0.0000000000 z= 2.5000000000
atom 11 x= -5.0000000000 y= 2.5000000000 z= 2.5000000000
From this it’s clear that
4 and 8 are ghosts of atom 0,
5 and 9 are ghosts of atom 1,
6 and 10 are ghosts of atom 2,
7 and 11 are ghosts of atom 3,
and the velocities of the ghosts are identical to those of their parents.
However, after the first step the velocities of the ghosts differ from those
of their parents, and the disagreement gets worse with every timestep.
After just one iteration I obtain:
atom 0 x= 0.0019761668 y= 0.0038294618 z= 0.0053116117
vx= 0.0004923162 vy= 0.0009560366 vz= 0.0013248753
atom 1 x= 2.4972097272 y= 2.5039690359 z= -0.0003621493
vx= -0.0006955450 vy= 0.0009907359 vz= -0.0000914899
atom 2 x= 2.4982139618 y= -0.0041591645 z= 2.5011762552
vx= -0.0004448536 vy= -0.0010381985 vz= 0.0002947187
atom 3 x= 0.0026001442 y= 2.4963606668 z= 2.4938742824
vx= 0.0006480824 vy= -0.0009085740 vz= -0.0015281041
atom 4 x= 5.0019761668 y= 0.0038294618 z= 0.0053116117
atom 5 x= 7.4972097272 y= 2.5039690359 z= -0.0003621493
atom 6 x= 7.4982139618 y= -0.0041591645 z= 2.5011762552
atom 7 x= 5.0026001442 y= 2.4963606668 z= 2.4938742824
atom 8 x= -4.9980238332 y= 0.0038294618 z= 0.0053116117
atom 9 x= -2.5027902728 y= 2.5039690359 z= -0.0003621493
atom 10 x= -2.5017860382 y= -0.0041591645 z= 2.5011762552
atom 11 x= -4.9973998558 y= 2.4963606668 z= 2.4938742824
Is this a bug? Is there a mistake in my test? Or am I simply
misunderstanding something? I’d be very grateful for any suggestions.
Comments for anyone who looks at my program in detail:
In the compute I calculate the total KE and PE and output them
together with the KE and PE as calculated by LAMMPs; these agree
with each other. At every step I also write x and v for the
first 12 atoms to the screen (a copy of the screen output is attached
in check_vel.out). The velocities of the real atoms (0,1,2,3) agree with
those dumped by LAMMPS.
Thanks in advance,
Philip
<<check_vel.out>> <<check_vel.param>> <<compute_heatflux3.cpp>> <<compute_heatflux3.h>>
check_vel.out (9.6 KB)
check_vel.param (694 Bytes)
compute_heatflux3.cpp (5.88 KB)
compute_heatflux3.h (1.06 KB)
