I’m new to LAMMPS and am trying to run a test problem to get familiar with the commands.
I’ve got a simple cubic lattice of atoms connected by a harmonic potential and am applying a uniaxial strain (in the x direction).
I’d like to adjust the y and z deformations to conserve volume but if I use the volume option in fix deform the domain collapses to a line
after one time step. My work around is to manually enter y and z deformations or strain rates to enforce volume conservation but I’m wondering
why the volume option does not work for this problem?
Here is contents of my input file and I’ve attached the data file containing atom positions and the bond list.
uniaxial strain test
unitsreal
boundaryp p p
atom_stylebond
read_data simple.dat
bond_styleharmonic
bond_coeff1 1.0 2.0
thermo_style custom step temp ebond lx ly lz pxx pyy pzz pxy pxz pyz
thermo 1
uniaxial extension with constant volume constraint (fails after one step)
#fix 1 all deform 1 x final -8.05 8.05 y volume z volume remap x units box
extension w/ constant volume work-around
fix 1 all deform 1 x final -8.05 8.05 y final -7.97511658 7.97511658 z final -7.97511658 7.97511658 remap x units box
timestep 1.0
dump 1 all atom 1 dump.coor
run 10000
Thanks for you help.
Todd
simple.dat (71.8 KB)
