I simulated a small system containing only 400 CO2 molecules at 308.15K(NVT).
I get consistent values for coulombic energy and total energies using Ewald
and pppm methods for long potential.
But, the final pressure is jumping all over the place. The box is 32×32×32
with CO2 density 0.89, which is corresponding to the CO2 critical state.
Therefor the expected average pressure should be 300atm finaly,
but my obtained result is 1013.17atm.
The typical results are obtained from last several steps of simulation only.
(1×10^6 steps in all, Ewald)
--------------- Step 998000 ---- CPU = 32206.6205 (sec) ---------------
Total E = 677.5437 Total KE= 1113.6373 Temp = 311.5973
Total PE= -436.0936 E_bond = 194.7543 E_angle = 158.9376
E_dihed = 0.0000 E_impr = 0.0000 E_vdwl = -663.3588
E_coul = 9596.0125 E_long = -9722.4393 Press = 1459.4498
--------------- Step 999000 ---- CPU = 32327.9993 (sec) ---------------
Total E = 627.5608 Total KE= 1074.9995 Temp = 300.7864
Total PE= -447.4387 E_bond = 193.6396 E_angle = 152.9668
E_dihed = 0.0000 E_impr = 0.0000 E_vdwl = -656.2266
E_coul = 9585.1683 E_long = -9722.9868 Press = 39.0421
--------------- Step 1000000 ---- CPU = 32368.4202 (sec) ---------------
Total E = 651.9472 Total KE= 1086.1959 Temp = 303.9192
Total PE= -434.2487 E_bond = 193.8684 E_angle = 166.6106
E_dihed = 0.0000 E_impr = 0.0000 E_vdwl = -654.6532
E_coul = 9583.0347 E_long = -9723.1093 Press = 1469.1984
The input script I use is below.(lammps 2001)
My input date file is attached to this email.
I appreciate any input.
#real system with NVT ensemble
units real
extra memory 1.5 1.5 4.0 1.5
maximum cutoff 18
neighbor 1 1 1 5 1
periodicity 0 0 0
read data data.co2
coulomb style ewald 10.0 1.0E-4
dielectric 1.0
nonbond style lj/cutoff 15.0 1
nonbond coeff 1 1 0.055639162 2.757 10.0
nonbond coeff 1 2 0.094128308 2.895 10.0
nonbond coeff 2 2 0.159242846 3.033 10.0
bond style harmonic
bond coeff 1 450 1.149
angle style harmonic
angle coeff 1 147.7 180
temp control nose/hoover 308.15 308.15 0.001
thermo flag 1000
thermo style 2
dump atoms 1000 dump.lj.nvt
restart 10000 2 file1 file2
timestep 1
run 1000000
data-isotropic.co2 (72.3 KB)
