Dear All,
I am trying to print position every 100 time step using fix print command,
fix ID group-ID print N string keyword value
using the example
fix extra all print 100 "Coords of marker atom = $x $y $z" file coord.txt
and I get this error Substitution for illegal variable.
And also I was searching in to this command to see how to print out velocity but I couldn’t see any example.
I would appreciate any suggestion.
Yasaman
Dear All,
using the example
Yasaman
Dear All,
using the example
to print out a variable, you first have to define it.
in any case, the best way to write out positions _and_
velocities is through using a custom-style dump.
check out the documentation.
Hi Axel
Thanks for your guiding me in right direction.It worked.
Yasaman
