Hi:
I had some problems with the Compass_published force field, but none in Oplsaa. What caused this?
Best Regards
Li-Yaomin
Hi:
Best Regards
Li-Yaomin
Hi Li-Yaomin
This is definitely a bug. (Even if there is a problem with your
files, moltemplate should always print a relevant error message.)
Can you send me your "system.lt" file as well as all of the other
".lt" files? (Please don't send them to the lammps mailing list.) I
will try running moltemplate (lttree_check.py) on your files, and fix
the bug. Hopefully that will help get you past your current impass.
Thanks for reporting this.
Andrew
