It seems to be problem problem with reseting “fix npt” command when simulation is started from restart file. It occurs in the latest version of lammps. I have two indications of it:
- temperature which is set in new simulation doesn’t assigned. simulation runs with old temperature
- if I change type of barostat (from aniso to x) - the error “PPPM - cannot calculate atoms” occurs
Can you check it?
Best regards, Konstantin.
