Hi everyone:
I wanna simulate alloy with single-element eam potentials.
For example, with cuu3 and auu3 I wrote like below:
pair_coeff 1 1 niu3
pair_coeff 2 2 alu9
but errors occur.
When I made a little change like this:
pair_coeff * * nialhjea 1 2
…” it works well.
Could anyone tell me why the former one does not work?
Thanks a lot!
See this page:
http://lammps.sandia.gov/doc/pair_style_eam.html
What pair_style command are you using? If you’re using eam/alloy, looks like the problem is that you haven’t defined you’re 1 2 cross interactions.
Paul
I use the eam pair_style because I don’t have the setfl file for the alloy I wanna
simulate. And I think the 1 2 cross interactions should be automatically done as
the instruction
" Different single-element files can be assigned to different atom types to model an alloy system. The mixing to create alloy potentials for type pairs with I != J is done automatically the same way that the serial DYANMO code originally did it; you do not need to specify coefficients for these type pairs."
But it does not work…
2006/12/20, Paul Crozier <pscrozi@…24… >:
