I want to try to do NVT simulation of Cu-Zr nanowire, but...the output
value is obviouly amusing.
The log files are put on the following.
LAMMPS (9 Jan 2009)
# Cu-Zr alloy b2 structure
atom_style atomic
read_data init-3.txt
orthogonal box = (-100 -20 -20) to (50 20 20)
1 by 1 by 1 processor grid
7856 atoms
mass 1 63.546
mass 2 91.224
velocity all create 100.0 8728
pair_style eam/alloy
pair_coeff * * ../../potentials/CuZr_mm.eam.fs Cu Zr
neighbor 2.0 bin
neigh_modify every 20 delay 0 check no
run_style verlet
fix 1 all nvt 100 100 0.01 drag 1.0
dump id all atom 10 dump.melt
timestep 0.001
thermo 1
thermo_style custom step temp ke pe etotal press
run 1000
Memory usage per processor = 5.74331 Mbytes
Step Temp KinEng PotEng TotEng Press
0 58.649937 59.549536 -6.017978e+14 -6.017978e+14 -9.0362764e+15
1 1.2814507e+21 1.3011062e+21 -1.5457072e+12 1.3011062e+21 5.7905604e+21
2 0 0 1.1924863e+15 1.1924863e+15 8.2020462e+15
3 0 0 3.7829393e+14 3.7829393e+14 8.0599385e+14
4 0 0 1.6091347e+14 1.6091347e+14 3.3592944e+14
5 0 0 2.4162933e+13 2.4162933e+13 -3.8427798e+14
6 0 0 3.210564e+13 3.210564e+13 1.655491e+12
7 0 0 1.5116975e+13 1.5116975e+13 -2.8849444e+14
8 0 0 7.2820291e+12 7.2820291e+12 1.6204298e+13
9 0 0 6.5326396e+12 6.5326396e+12 1.4536724e+13
10 0 0 9.2400521e+12 9.2400521e+12 2.056138e+13
11 0 0 5.9406095e+12 5.9406095e+12 1.3219313e+13
12 0 0 9.7703454e+12 9.7703454e+12 2.1741413e+13
13 0 0 5.115046e+12 5.115046e+12 1.1382231e+13
14 0 0 2.4514948e+12 2.4514948e+12 5.4551767e+12
15 0 0 1.3576798e+13 1.3576798e+13 3.0211706e+13
16 0 0 2.6840773e+12 2.6840773e+12 -2.3787875e+15
17 0 0 6.6557008e+12 6.6557008e+12 1.4810567e+13
18 0 0 3.5327626e+13 3.5327626e+13 7.8612629e+13
19 0 0 1.3483534e+13 1.3483534e+13 3.0004169e+13
ERROR: Lost atoms: original 7856 current 10
Why are the value of pressure , potential energy and total energy large
? Cannot you make them smaller?
Please answer.
Keiju
