Dear LAMMPS users,
I am now using "fix thermal/conductivity" command to calculate thermal
conductivity for my system. However, the temperature profile between the hot and
cold slabs does not seem to change with time. I tried to increase Nswap to 200
steps, but it did not work.
The followings are my input scripts and output temperature profile. I would be
appreciate if someone can give me some advices.
Sincerely,
Keng-Hua Lin
========================input script====================================
#Si
units real
atom_style atomic
lattice diamond 5.43 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region box block 0 1 0 1 0 1 units lattice
create_box 1 box
create_atoms 1 box
mass 1 28.0855
replicate 3 3 10
pair_style sw
velocity all create 300.0 82373 dist gaussian
pair_coeff * * SiGe.sw Si #can also be defined in datafile
timestep 1.00000000
thermo 50
#---------------flux calculation -------------------------------------
compute ke all ke/atom
variable temp atom c_ke*1000/(1.5*1.98721)
fix 3 all ave/spatial 1 5000 10000 z lower 0.1 v_temp file tmp.profile
units reduced
fix 2 all thermal/conductivity 50 z 10
variable DeltaPe equal f_2
thermo_style custom etotal ke pe temp press vol pxx pyy pzz pxy pxz pyz lx
ly lz v_DeltaPe
thermo_modify flush yes line multi
log NPT300K_DeltaPe_BulkSi.log
run 100000
========================temperature profile===============================
# Spatial-averaged data for fix 3 and group all
# Timestep Number-of-layers
# Layer Coord Ncount v_temp
10000 10
1 0.05 72 132.035
2 0.15 72 314.859
3 0.25 72 262.382
4 0.35 72 291.567
5 0.45 72 293.415
6 0.55 72 518.897
7 0.65 72 307.96
8 0.75 72 291.909
9 0.85 72 290.409
10 0.95 72 292.393
20000 10
1 0.05 72 132.035
2 0.15 72 314.859
3 0.25 72 262.382
4 0.35 72 291.567
5 0.45 72 293.415
6 0.55 72 518.897
7 0.65 72 307.96
8 0.75 72 291.909
9 0.85 72 290.409
10 0.95 72 292.393
100000 10
1 0.05 72 132.035
2 0.15 72 314.859
3 0.25 72 262.382
4 0.35 72 291.567
5 0.45 72 293.415
6 0.55 72 518.897
7 0.65 72 307.96
8 0.75 72 291.909
9 0.85 72 290.409
10 0.95 72 292.393
