Dear Steve,
I have a quick question regarding logplot.py in python tool. Is it somehome possible to plot the thermo output using xmgrace instead of gnuplot using the logplot.py? I know I may have to write some code or modify some file. But I will appreciate any suggestions where I should look into. The reason being grace is much for flexible then gnuplot.
One other modification. In the README file of python tool directory, the enviroment variable LAMMPS_TOOLS_PYTHON is different than the one which is in logplot.py and other scripts ( LAMMPS_PYTHON_TOOLS). Please update it as it may confuse some of the users.
Thanks.
Vikas
HI Vikas,
Dear Steve,
In logplot.py is this line:
g = gnu()
which uses the module gnu.py (in the lower level dir).
That line could be changed to g = xmgrace(), but only
if there was a xmgrace.py that was a wrapper around XMGRACE
(like gnu.py is a wrapper around GnuPlot). Ideally the wrapper
would support the same interface that GnuPlot and MatLab does
within Pizza.py. I.e. those 2 packages can be used interchangeably
b/c the interface is the same.
So someone needs to write xmgrace.py with the desired interface.
Made the change -thanks
