I am sending all the command lines and output i got when compiling lammps. First i used the command “make” and after that i tried "make linux " to generate the execultable file. But it showed a lot of errors. Can some one mail me the executable file of lammps version of 7th july if they have one??
Ajit
autohome/u106/lammps-7Jul09/src$ make
make clean-all delete all object files
make clean-machine delete object files for one machine
make tar lmp_src.tar.gz of src dir and packages
make makelib update Makefile.lib for library build
make makelist update Makefile.list used by old makes
make package list available packages
make package-status status of all packages
make yes-package install a single package in src dir
make no-package remove a single package from src dir
make yes-all install all packages in src dir
make no-all remove all packages from src dir
make yes-standard install all standard packages
make no-standard remove all standard packages
make yes-user install all user packages
make no-user remove all user packages
make package-update replace src files with package files
make package-overwrite replace package files with src files
make machine build LAMMPS where machine is one of:
