Dear Christopher,
It depends on what crystal structure you are going to use in your
system. For example, in case of CsCl, it is having two basis in a unit
cell, for which the lattice command will be
lattice custom 5.0 a1 1.0 0.0 0.0 a2 0.0 1.0 0.0 a3 0.0 0.0 1.0
basis 0.0 0.0 0.0 basis 0.5 0.5 0.5
Similarly to large no of basis also you can write the lattice command,
but you should know the position of atoms in a unit cell.
Hope so it will help you
Goodluck
Vijay
Thank you, Sir. Now I understood what itype arg means. The 2 basis atom
in the unit cell are the same, so itype=1.
I have 1 query on defining basis atom using lattice command. If my
system is a simple cubic or space group = P 1, then I will use lattice
… custom … basis 0 0 0 . However, my complicated organic crystal
has a space group = P 1_bar or P -1, which implies that the second
basis is in an inversion position to the first basis. If I were to use
lattice with custom command, then I’ll define basis 0 0 0 for the first
basis, but what fraction should I use to define the position for the
second basis?
Thank you very much.
Regards,
Christopher
