I want to know how to use the min_style(cg) command effectively. I tried to use this command along with NVT and found that there is no significant difference in potential energy before and after using it. I also didn't see any rearrangement of atoms in the trajectory
I want to know how to use the min\_style\(cg\) command
min_style only applies to using "minimize".
while fix nvt only applies to using "run".
so it is not quite clear what you are trying to achieve.
