Dear All,
I want to make sure the proper way to simulate annealing and cooling process with LAMMPS. I think I can simulate annealing and cooling process by using fix NPT or NVT command. We can assign initial temperatur with Tstart parameter and final temperature with Tstop parameter. One can control cooling/annealing rate by seting Tdamp parameter. Is it right? . Is there other way?
NPT and NVT means ensamble with temperature constant(isothermic). ButAnnealing and quenching are not isothermic process. this to be honest puzzled me.
thank you in advance
with best regards,
Mauludi
