Thanks for your help these days. Now I have another question. When using fix reax/bond, lammps generates a file of bond information, containing the bond order and so on. What’s the meaning of abo and nlp in it?
And now I want to visualize my result and draw bonds between atoms. Does the coarse bond order cutoff 0.3 in the file mean that if the bond order is below this value, it should not be considered as a bond and should not be drawn? Sometimes the distance of two atoms exceeds the normal bond length, but the bond order given by reax is still high (like 0.5). I feel strange. Could you give some suggestion about drawing the bonds. Thanks.
