Hi all: I am trying to specify a branched connectivity using FENE
bonds. But LAMMPS has difficulties in identifying 1-3 neighbors with
this connectivity and the simulation collapsed. So I guess LAMMPS only
supports linear connectivity, but not branched ones like two linear
chains joined at middle points. Does LAMMPS support branched
connectivity?
connectivity?
yes. are you sure your special_bonds setting is correct?
LAMMPS can handle some extremely complex connectivities, including chains grafted onto amorphous silica.
Are you sure that you're specifying your model correctly? More likely than not there's an error in your input files—wrong unit set, or connectivity problems.
