I used the example for testing fix deposit, If you could give any suggestions, I will appreciate it.
as steve already mentioned. the problem is due to the use of
using fix nvt on a system where you add atoms. nose-hoover
thermostat chains are not very forgiving as to such disruptions.
you have to use a "stateless" thermostat like langevin or berendsen.
