Hi LAMMPS users
I inserted two types of particles in my simulation's box by pouring. In my
simulations, an easy example that I made was: an box with 1000 particles of
diameter 2d (on the bottom) plus 1000 particles of diameter d (above)
approximately, but I had problems with the visualization of different particles.
I'm using the "fix_insert" for to insert the particles inside the box:
fix ins1 all insert 1000 1 300719 diam 1.0 1.1 region slab
fix ins2 all insert 1000 2 300719 diam 0.5 0.6 region slab
I'm using the pizza.py toolkit for visualization. I ran the lammps for my
in.teste and a dump.teste was created. After in the pizza, I used the tool gl.py:
d = dump("dump.teste")
g = gl(d)
g.box(1)
g.all()
so I looked the animation and many images PNG was created for each snapshot.
In this images, I see each type of particle with a different color, but my
problem is: all the particles have the same size, I don't see the biggest particles.
I'd like to know, how can I visualize the different particles? What can I do to
look the particles with different diameters in the same box?
Thanks a lot.
Aline
