[lammps-users] Question about lammps capabilities
Can lammps be used to simulate the behavior of magnetic solid particles in suspension under an external magnetic field (like for instance a magnetorheological fluid)?
Thanks for the help
Marcio
If you could write a fix that imposes a force on
particles due to a H field you define, then
you could use LAMMPS to run dynamics.
See for example fix efield for an imposed E field.
