[lammps-users] question on compute command
It seems that there is not an option for output frequency number in compute command (e.g. compute stress).
If so, is “compute command” calculated every step during running?
Otherwise, is it calculated only when it is called in other command (e.g., when “fix command” in which c_mystress[1] is used is performed where mystress is ID of “compute stress”)?
Is there a method to avoid every step calculation of “compute command” if it is calculated every step generally? (Should I use “if statement”?)
Luke
It's not computed every step - only when
some other command (e.g. thermo, dump)
requests it.
2010/10/26 JhonY. I. <[email protected]...>:
