Dear All,
I am using the following fix for my simulation:
fix 2 Rea2 bond/create/angle 100 1 14 4.0 5 aconstrain 160 180 prob 1 25784 iparam 1 15 jparam 1 13 atype 6
for creating bonds with the constrain of angles.
I am sure that each of the type 1 and type 14 atom is bonded with another atom.
For example: atom1(type 1) bonds with atoms2(type 7), atom3(type 14) bond with atom4(type 8).
So, for the bond forming between atom1 and atom3. It requires meeting all the following criteria that :
- distance meeting atom1 and atom3 within 4 Angs.
- Angle1 (atom2-atom1-atom3) within the range of [160,180]
- Angle2 (atom2-atom3-atom4) within the range of [160,180]
However, when I check my simulation trajectory, it will create a bond when only angle1 is meet the criteria, and it can not find angle2 when I use mpirun with more than 4 cores. I am using the cpu chip of AMD EPYC7702.
I modified the debug code provided by Jacob https://github.com/lammps/lammps/pull/2206
on the latest stable version of Lammps which is LAMMPS (30 Nov 2020).
I can get the following information,
case I
i is 192, j is 1011
bond/create/angle: angle1 no J is 1.632267
which means the i atom find at least 1 neighbor in nspecial, however the j atom didn’t. (refers to fix_bond_create_angle.cpp in src of lammps)
However my i or j atoms always bond with another atom, it should always give me :
case II
i is 512, j is 716
bond/create/angle: angle1 is 1.880515, angle2 is 2.361167
When I use only 1 core to run the simulation, it seems everything is correct, and they can always find out both angle1 and angle2. So I am wondering if this is a problem created by using multiple processors for running the simulation, which the special lists didn’t communicate well between processors. But I can not afford for using only 1 CPU to run my simulation.
Is there any way that can help solve this issue other than using only 1 CPU?
Toby
