Hi lammps users,
I have been using reax/c pair_style for simulating polyethylene cnt nanocomposite. Now I changed my material to epon teta cnt nanocomposite. Two main changes I made from my cnt polyethylene code: changed data file and force field file, which are obvious changes to be made. But while using mpirun -np 6 lmp_mpi -i input.epoxy_cnt I got the following error:
Signal: Segmentation fault (11)
Signal code: Address not mapped (1)
Failing at address: 0x1a1…
Is this an error due to the lmp_mpi executable or a problem with my code? Any suggestions?
Regards
Abhiram
control_file (692 Bytes)
ffield.reaxc.cnt_epoxy (15.5 KB)
param.qeq (217 Bytes)
input.epoxy_cnt (2.15 KB)
epoxy.data (727 KB)
