Hello all,
When I run the reax example, it said that the pair_style is not valid. I have already built the reax package successfully (obtaining a libreax.a file on the lib/reax dir) and also included it in the LAMMPS build (with the make yes-reax command). I understand the makefile on the src/Make dir must be modified in order to have correct settings for reax_SYSLIB and reax_SYSPATH. I would greatly appreciate a model makefile.mac_mpi (obviously for mac) or an explanation on how to perform a cross-language link using the system’s Fortran libraries.
Thank you in advance,
Alejandro MartÃnez G.
Graduate Assistant
Department of Chemical Engineering
Universidad de los Andes
