Hi all,
I am trying to relax the Carbon-nanotube for energy minimization (geometrical optimization) using Tersoff potential in LAMMPS. I have few questions regarding this approach:
1) Since, I am using the tersoff potential, so I do not need to define the bond-type. But suppose, my CNT is distorted such that there are some bonded and some non-bonded carbon atoms in my structure, then how should I modify the script to take into account this factor?
2) For defining the pair_coefficient, the tutorial says that we must write all the atoms in the pair_coefficient command. For example: pair_coefficient * * Si.tersoff C C C C, if my structure has 4 atoms. But when my structure has, lets say, 400 atoms, then how do we write the pair_coefficient command? I'm assuming that we do not need to write C 400 times.
3) Lastly, when I run the script attached with this email, I get the error: ERROR: Incorrect args for pair coefficients. Please suggest what should I modify in the script to get past this error.
Thank you.
alpha21
in.gcg3 (999 Bytes)
data.gcg4 (16.8 KB)
Hi all,
please read the publication describing the tersoff potential
and its uses. this should clarify why this kind of many-body
potential can handle different "bond orders".
it says atom _types_.
if your system is all carbon nanotube there should
be only one atom type.
write C 400 times.
only if you insist on assigning a new atom type for each atom,
which would probably also have a bad impact on performance.
there is no need for it.
before i am looking at the script. please consider the
aforementioned suggestions and see if you can fix the
problem by yourself. it should be no rocket science.
cheers,
