Hello everyone,
I ran about 100 chains in my simulations (in Jan 2009 version) .
And i like to calculate the average of gyration of molecules.
When i use as follows
group mol1 molecule <> 1 100
fix 1 mol1 gyraton 10000 rg.out
When i get the results, i found that lammps consider mol1 as a molecule, and the gyration is for mol1.
How can i calculate the average gyration of each molecule?
Thanks in advance
Houyang
Upgrade the newest version of LAMMPS, and you can do something like this:
compute calcrg poly gyration/molecule #makes vector of all the Rgs
compute rgave poly reduce ave c_calcrg #averages the values in the vector
fix outrg poly ave/time 1000 1 1000 c_rgave file averg.out #prints the average Rg
Lisa
Hello, Lisa,
Thanks.
I will do it.
Houyang
Hi,Lisa
i did the work as you suggested. However, i found some problems.
The command i used like:
group poly molecule <> 1 100
fix outrg poly ave/time 100 1 100 c_rgave file tmp1.dat
compute calcrg1 poly gyration/molecule
fix outrg1 poly ave/time 1000 1 1000 c_calcrg1 &
mode vector file tmp2.dat
I added your commands (slightly modified, see above) to bench/in.chain and
looked at the two output files: tmp1.dat and tmp2.dat. They
are in good agreement. One has the ave value, about 5, the other
has a spread of values from about 4 to 6. So I'm not
seeing the kind of issue you discuss. Are you running the most
current version of LAMMPS?
Steve,Lisa,
Sorry. I made a mistake in my file.
It is OK now.
Thanks & Best wishes
Houyang
