Hi all,
I have a question concerning the set of atom displacement. I my project I m trying
to investigate de diffusive behavior of BaTiO3 including oxygen vacancies in the
temperature range 773-673K.
I was minimized the structure but when I try to run MD under PBC and nph ensemble
controlling the temperature with Berendsen Thermostat, to obtain msd of oxygen ion,
not diffuse. I believe that the problem is concerning to the pressure values, I want
to do it under atmospheric pressure (P=0GPa). I used the Virial correction to input
the pressure but nothing.
I did these simulations before by suing other software but LAMMPS is faster and I
want to learn.
Attached are two files: the minimization and equilibration and the MD run input files:
Waiting for your help
Yohandys
####--------------in.min------------------------------------------------------------------------####
# minimization
atom_style charge
atom_modify map array sort 0 10.0
neighbor 0.5 bin # I don't know if it is correct
neigh_modify delay 0 every 1 check no
lattice custom 16.04 a1 1 0 0 a2 0 1.0 0 a3 0 0 1 basis 0 0 0
read_data BT4x4x4.dat # 4x4x4 BaTiO3 unit cell
##########################################################################-----------------------Atoms
Definitions----------------------####
###################################################################### group Ti
type 1 group o type 3
group Ba type 2
set group o charge -2.0
set group Ti charge 4.0
set group Ba charge 2.0
mass 1 47.88
mass 2 137.33
mass 3 16.00
in.min (3.13 KB)
in.dyn (2.16 KB)
