How to restart parallel tempering runs from the previously saved state.
In my first run I have used
You need a read_restart command that reads a different
file on each partition, corresponding to the restart files
you wrote out - i.e. use a variable in the file name. Since each
of those files will be at a different temperature, I think you also
need to re-order your t variable to match the permuted ordering.
Since each
This was wrong advice. Instead use the final "index" variable as
part of the temper command, as discussed on the temper doc page.
