i have this system i want to minimize only in the z-direction, that's, i want to leave its x and y atomic coordinates
constant.
Does the minimize command allow for doing this kind of minimizations?
Regards
Miguel
constant.
Regards
Miguel
I haven't tried it, but I think you could use fix setforce to set the
x,y force components to 0.0, and it would work.
Steve,
thanks.
Sounds reasonable, but i have a small question. Say i set fx and fy equal
to 0.0, whereas i want fz to change. How does one indicate this with setforce?
setforce 0.0 0.0 seems to not be correct way of doing it.
In the manual i only see two possibilities: using NULL or using a variable.
NULL is not what i want, since this let that force with its current value.
As for the variable, i'm not sure this is either what i want.
Regards
Miguel
Miguel,
You probably want something like this:
fix 1 all setforce 0.0 0.0 NULL
Paul
